SMASSEMBLYEXPORTMODE system variable
Modification of exported assemblies
Specifies whether the original assembly is modified after running the SMASSEMBLYEXPORT command.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Valori possibili: |
0: Do not change external components 1: Keep recognized features on sheet metal/poor sheet metal parts |
