SMASSEMBLYEXPORTMODE system variable
Modification of exported assemblies
Specifies whether the original assembly is modified after running the SMASSEMBLYEXPORT command.
BricsCAD only
Type:
Short
Saved in:
Registry
Possible values:
0: Do not change external components
1: Keep recognized features on sheet metal/poor sheet metal parts
