SMASSEMBLYEXPORTMODE system variable
Modification of exported assemblies
Specifies whether the original assembly is modified after running the SMASSEMBLYEXPORT command.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Possible values: |
0: Do not change external components 1: Keep recognized features on sheet metal/poor sheet metal parts |
