SMASSEMBLYEXPORTREPORTPATHTYPE system variable
Report file path type
Determines whether absolute or relative path to files will be used in the reports generated by the command.
BricsCAD only
Type:
Short
Saved in:
Drawing
Range:
0 to 1
Default value:
0
Possible values:
0: Relative paths
1: Absolute paths
