SMASSEMBLYEXPORTREPORTPATHTYPE system variable
Report file path type
Determines whether absolute or relative path to files will be used in the reports generated by the command.
BricsCAD only
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: Relative paths 1: Absolute paths |
