SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
Solid types in reports
Determines which types of solids will be present in command reports. Each solid belongs to one of four types: sheet metal, poor sheet metal, non sheet metal or standard part component solid. Sheet metal and poor sheet metal solids are always present in the reports.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Disegno |
Gamma: |
0 to 3 |
Valore predefinito: |
0 |
Valori possibili: |
1: Non sheet metal solids 2: Standard part component solids |
