SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
Solid types in reports
Determines which types of solids will be present in command reports. Each solid belongs to one of four types: sheet metal, poor sheet metal, non sheet metal or standard part component solid. Sheet metal and poor sheet metal solids are always present in the reports.
BricsCAD only
Type:
Short
Saved in:
Drawing
Range:
0 to 3
Default value:
0
Possible values:
1: Non sheet metal solids
2: Standard part component solids
