SMBENDLINESUPLAYERLINEWEIGHT system variable
Lineweight of the bend up layer
Determines the lineweight of the bend up layer. Values between -3 and 211 are accepted. -1=ByLayer, -2=ByBlock, -3=Default
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-3 to 211 |
| Default value: |
-3 |
