SMCONTOURSLAYERLINEWEIGHT system variable
Lineweight of the contour layer
Determines the lineweight of the Contour layer. Values between -3 and 211 are accepted. -1=ByLayer, -2=ByBlock, -3=Default
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
-3 to 211 |
Valore predefinito: |
30 |
