SMDEFAULTBENDLINEEXTENTTYPE system variable
Bend line extent type
Determines if bend line extent is thickness ratio or absolute value. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
0 |
| Possible values: |
1: Thickness ratio 2: Absolute value |
