SMDEFAULTBENDLINEEXTENTVALUE system variable
Bend line extent value
Controls how much bend lines stretch out of contour (if the value is positive), do not reach it (if the value is negative), or just touch it (if the value is zero). Value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Range: |
-1000000 to 1000000 |
| Default value: |
0.25 |
