SMDEFAULTBENDRADIUSTYPE system variable
Bend radius type
Determines whether bend radius value is to be treated as ratio to thickness or absolute value. The first switch toggles Thickness ratio/Absolute value. The second switch controls whether Sheet Metal context bend radius setting has to be taken from SMDEFAULTBENDRADIUSVALUE or from the recognized model.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Disegno |
Gamma: |
0 to 3 |
Valore predefinito: | 2 |
Valori possibili: |
1: Absolute value 2: Override bend radius in SMCONVERT |
