SMDEFAULTBENDRELIEFWIDTHTYPE system variable
Bend relief type
Determines whether the bend relief width value will be treated as ratio to thickness or absolute value. The value will be used to initialize sheet metal settings in the document.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
