SMDEFAULTFLANGESPLITGAPTYPE system variable
Miter gap type
Determines whether miter gap is to be treated as ratio to thickness or absolute value. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: | 0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
