SMDEFAULTFORMFEATUREUNFOLDMODE system variable
Form feature unfolding mode
Determines appearance of form features in unfolded part. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
4 |
| Possible values: |
0: Keep 1: Remove 2: Project 3: Contour 4: Symbol 5: Project without center mark 6: Contour without center mark |
