SMDEFAULTGUSSETDEPTHTYPE system variable
Gusset depth type
Determines whether the gusset depth value is to be treated as ratio to thickness or absolute value. The value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 1 |
Default value: | 0 |
Possible values: |
0: Thickness ratio 1: Absolute value |
