SMDEFAULTGUSSETFILLETRADIUSTYPE system variable
Gusset fillet radius type
Determines whether the gusset fillet radius value is to be treated as ratio to thickness or absolute value. The value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: | 0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
