SMDEFAULTGUSSETTYPE system variable
Gusset type
Determines whether the gusset will be round or flat. The value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type: |
Short |
Saved in: |
Drawing |
Range: |
1 to 2 |
Default value: | 1 |
Possible values: |
1: Round 2: Flat |
