SMDEFAULTGUSSETWIDTHTYPE system variable
Gusset width type
Determines whether the gusset width value is to be treated as ratio to thickness or absolute value. The value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: | 0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
