SMDEFAULTHEMGAPTYPE system variable
Open Hem gap type
Determines whether the corresponding hem feature gap is to be treated as ratio to thickness or absolute value. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: | 0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
