SMDEFAULTHEMRELATIVEBENDDEDUCTION system variable
Hem relative bend deduction value
Sets relative to thickness bend deduction value used for closed hem unfolding. Value ranges from 0 which leads to hem lengthening to 10 which means shortening bend zone by a value equal to 8 * thickness. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Range: |
0 to 10 |
Default value: |
2.4 |
