SMDEFAULTKFACTOR system variable
K-Factor value
Sets location ratio of the neutral surface, for example surface not stretched or squeezed when the sheet is bent, to the material thickness. Value ranges from 0 for internal bend radius to 1 for the external bend radius. Value will be used to initialize sheet metal settings in the document.
Solo-BricsCAD
Tipo: |
Reale |
Salvato in: |
Disegno |
Gamma: |
0 to 1 |
Valore predefinito: |
0.27324 |
