SMDEFAULTKFACTOR system variable
K-Factor value
Sets location ratio of the neutral surface, for example surface not stretched or squeezed when the sheet is bent, to the material thickness. Value ranges from 0 for internal bend radius to 1 for the external bend radius. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type:
Real
Saved in:
Drawing
Range:
0 to 1
Default value:
0.27324
