SMDEFAULTRIBPROFILERADIUSTYPE system variable
Bead profile radius type
Determines whether bead profile radius to be treated as ratio to thickness or absolute value. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type:
Short
Saved in:
Drawing
Default value: 0
Possible values:
0: Thickness ratio
1: Absolute value
