SMDEFAULTSHARPBENDRADIUSLIMITRATIO system variable
Sharp bend radius limit ratio
The default sharp bend radius limit ratio to the thickness. Value will be used to initialize sheet metal settings in the document.
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Default value: | 5 |
