SMDEFAULTTABCHAMFERDISTANCETYPE system variable
Tab chamfer distance type
Determines whether tab chamfer distance will be treated as ratio to profile radius or absolute value. The value will be used to initialize sheet metal settings in the document.
Tipo: |
Breve |
Salvato in: |
Disegno |
Gamma: |
0 to 1 |
Valore predefinito: |
0 |
Valori possibili: |
0: Thickness ratio 1: Absolute value |
