SMDEFAULTTABDISTANCETYPE system variable
Tab distance type
Determines whether tab distance will be treated as ratio to profile radius or absolute value. The value will be used to initialize sheet metal settings in the document.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
