SMDEFAULTTABFILLETRADIUSTYPE system variable
Tab fillet radius type
Determines whether tab fillet radius will be treated as ratio to thickness or absolute value. The value will be used to initialize sheet metal settings in the document.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Thickness ratio 1: Absolute value |
