SMDEFAULTTABLENGTHTYPE system variable
Tab length type
Determines whether tab length will be treated as ratio to profile radius or absolute value. The value will be used to initialize sheet metal settings in the document.
Tipo: |
Breve |
Salvato in: |
Disegno |
Gamma: |
0 to 1 |
Valore predefinito: |
0 |
Valori possibili: |
0: Thickness ratio 1: Absolute value |
