SMOOTHMESHCONVERT system variable
Mesh conversion mode
Specifies mesh to 3d solid or surface conversion mode, used by commands CONVTOSOLID or CONVTOSURFACE. Currently we support conversion only to faceted models, so values 0 and 1, corresponding to conversion to smooth models, are not accessible.
Tipo: | Breve |
Salvato in: | Non salvato |
Gamma: |
2 to 3 |
Valore predefinito: |
2 |
Valori possibili: |
2: Conversion result is faceted and optimized 3: Conversion result is faceted and not optimized |
