SMPARAMETRIZEHOLESPARAMETRIZATION system variable
Hole parametrization
Controls parametrization for straight holes. If Convert holes to array is on, holes on flanges will be checked to be grouped into parametric rectangular array. If Parametrize holes is on, holes which are not included to arrays will be constrained.
BricsCAD only
Type:
Short
Saved in:
Drawing
0 to 3
Default value:
3
Possible values:
0: Does not parametrize holes
1: Parametrize holes
2: Convert holes to array
