SNAPISOPAIR system variable
捕捉等角平面
Specifies the current viewport's isometric plane (left, top or right), used if SNAPSTYL is isometric. Press F5 function key to set the appropriate drawing plane: Left, Top or Right.
Type:
Short
Saved in:
Drawing
Range:
0 to 2
Default value:
0
Possible values:
0: Left
1: Top
2: Right
