SNAPUNIT system variable
Snap unit
Specifies the current viewport's snap spacing and specifies the spacing between snap points. If SNAPSTYL is 1 (isometric snap), the SNAPUNIT X value will adjust itself automatically to reflect the isometric snap. There is no snap in the Z direction.
Tipo: |
Punto 2D |
Salvato in: | Disegno |
Valore predefinito: |
0.5,0.5 |
