SNAPUNIT system variable
捕捉间距
Specifies the current viewport's snap spacing and specifies the spacing between snap points. If SNAPSTYL is 1 (isometric snap), the SNAPUNIT X value will adjust itself automatically to reflect the isometric snap. There is no snap in the Z direction.
Type: |
2D point |
Saved in: | Drawing |
Default value: |
0.5,0.5 |
