SORTENTS system variable
Sort entities
Specifies the entity display sort order. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: |
0 to 127 |
Valore predefinito: |
127 |
Possibili opzioni: |
0: Off 1: Entity selection 2: Entity snap 4: Redraws 8: Mslide slide creation 16: Regens 32: Plotting 64: PostScript output |
