SORTENTS system variable
对象排序
Specifies the entity display sort order. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: |
0 to 127 |
Default value: |
127 |
Possible options: |
0: Off 1: Entity selection 2: Entity snap 4: Redraws 8: Mslide slide creation 16: Regens 32: Plotting 64: PostScript output |
