SORTENTS system variable
Sort entities
Specifies the entity display sort order. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 127 |
| Default value: |
127 |
| Possible options: |
0: Off 1: Entity selection 2: Entity snap 4: Redraws 8: Mslide slide creation 16: Regens 32: Plotting 64: PostScript output |
