SPAADJUSTMODE system variable
调整模式
The adjustment mode is used for triangle smoothing. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 2 |
Default value: |
0 |
Possible values: |
0: 无 (全部不调整) 1: 无格点 (移动三角形包围节点在中心周围的节点) 2: 全部(也调整网格点) |
