SPAADJUSTMODE system variable
Adjust mode
The adjustment mode is used for triangle smoothing. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
0
Possible values:
0: None (Leave everything alone)
1: Non grid (Adjust points surrounded by triangles by moving nodes in the center of surrounding nodes)
2: All (Also adjusts grid nodes)
