SPAGRIDASPECTRATIO system variable
Grid aspect ratio
Grid aspect ratio specifies the approximate aspect ratio of each cell in the grid. If the value is close to 1, then the cell is close to a square. This does not guarantee the aspect ratio of the facet, which may consist of only a part of a cell. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
Solo-BricsCAD
Tipo: | Reale |
Salvato in: | Preferenza |
Valore predefinito: |
0.0 |
