SPAGRIDMODE system variable
格点模式
Specifies how grids are used in the mesh process. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 3 |
Default value: |
1 |
Possible values: |
0: 没有格点 1: 格点在内部 2: 允许栅格等分模型 边 3: 格点只在一个方向,U或V |
