SPAGRIDMODE system variable
Grid mode
Specifies how grids are used in the mesh process. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 3 |
Default value: |
1 |
Possible values: |
0: No grids at all 1: Grids in interior 2: Allow grid to divide model edges 3: Grid only in one direction, u or v |
