SPAMAXFACETEDGELENGTH system variable
Maximum facet edge length
Specifies the maximum length of a facet side. The recommended, and default, value of 0 allows the software to determine and use an optimal value. Specifying a length that is too small can lead to high memory consumption and poor performance. This variable is ignored if SPAUSEFACETRES is used.
Solo-BricsCAD
Tipo: |
Reale |
Salvato in: |
Preferenza |
Valore predefinito: |
0.0 |
