SPAMAXFACETEDGELENGTH system variable
Maximum facet edge length
Specifies the maximum length of a facet side. The recommended, and default, value of 0 allows the software to determine and use an optimal value. Specifying a length that is too small can lead to high memory consumption and poor performance. This variable is ignored if SPAUSEFACETRES is used.
BricsCAD only
Type: |
Real |
Saved in: |
Preference |
Default value: |
0.0 |
