SPAMAXNUMGRIDLINES system variable
Maximum number of grid lines
The maximum grid lines specifies the maximum number of grid subdivisions. This prevents the facet data of a face from getting too big. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
Solo-BricsCAD
Tipo: | Lungo |
Salvato in: | Preferenza |
Valore predefinito: |
512 |
