SPAMINUGRIDLINES system variable
Minimum number of U grid lines
Specifies the minimum number of U grid lines. At least this number of grid lines are generated in U direction. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
Solo-BricsCAD
Tipo: | Lungo |
Salvato in: | Preferenza |
Valore predefinito: |
0 |
