SPAMINUGRIDLINES system variable
Minimum number of U grid lines
Specifies the minimum number of U grid lines. At least this number of grid lines are generated in U direction. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Long |
Saved in: | Preference |
Default value: |
0 |
