SPAMINVGRIDLINES system variable
Minimum number of V grid lines
Specifies the minimum number of V grid lines. At least this number of grid lines are generated in V direction. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
Solo-BricsCAD
Tipo: | Lungo |
Salvato in: | Preferenza |
Valore predefinito: |
0 |
