SPAMINVGRIDLINES system variable
Minimum number of V grid lines
Specifies the minimum number of V grid lines. At least this number of grid lines are generated in V direction. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Long
Saved in:
Preference
Default value:
0
