SPASURFACETOL system variable
曲面公差
The surface tolerance specifies the maximum distance between a facet edge and the true surface. The proper value is dependent on the model size. This variable is ignored for output to STL and PDF if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Real |
Saved in: | Preference |
Default value: |
-1.0 |
